Vista 64 CRT driver problem
26 Mar 2003
Hertfordshire
I've just moved to Vista 64 bit and i'm on a CRT, the problem is i can't install the driver for my Misubishi Diamond Pro 750 SB and so i'm losing out on some refresh rates, for example 800 x 600 @ 140hz.
I tried installing the XP driver and it won't allow, anyone know if i can get around this?
If there's no driver there's not a lot you can do in that department, you may be able to get a 3rd party program to force the setting for you though.
What graphics card do you have?
8800 gts
i used to manipulate the old XP ini so it could display 2048x1536 for testing purposes, if i can't find a way to do the same in vista i'm screwed.
