Vista 64 Defrag problem....
5 Jan 2005
Engerland :)
ok after installing all my stuff I thought Id defrag drive.
downloaded Diskeeper trial..... drive said 30 odd % messed up so I hit defrag....
after completing and checking again... the result was the same!
so after a few more tries... using the other methods same result.
Uninstalled and tried Ultimate Defrag.... guess what same results.
30 odd % fragmented.
Am using 2 x 150gb raptors in raid for OS.
Any ideas why this happening ?
Not sure why it's happening but give TuneUP Utilities a go. Defraged my 250GB OS Hdd in about 25minutes :)
Has anyone used Defraggler?
I've heard good things about it, but a bit reluctant to use a defragger that's in beta!
JKDefrag + JKDefrag GUI for an easy to use and totally free defragger.
I used to use Diskeeper, have totally stopped after finding JKDefrag.
Simple little tool that does what it is supposed to without any fuss.
system restore files aren't touched by defrag
disable that first
o&o defrag runs really well in vista
tried that one.
It said didnt need defragging and stopped !
Not sure why the others are saying 40 odd %
disable that first
Havent done the system restore thing yet - but O & O was the same giving a big fragmentation figure but then not been able to sort it.
Will disable system restore and try again.
cheers guys
just turned off system restore and then ran analyze under ultimate defrag and said there was minimal ..... so I guess it was the System restore files that wouldnt budge as stated.
Thanks !
