Vista 64 flash player and activex
17 Oct 2006
Aviemore, Cairngorms, Scottish Highlands
Some one please help or explain i got vista prem 64bit and having problems seeing videos etc on myspace now i've installed flash player 9 and the same thing goes for activex on some web sites its just driving me mad, i want to stick with IE and not firefox etc also whats the diffrence between runnning IE 32bit and IE 64bit :confused:
Just use the IE32bit version.
IE7 should be installed in both 64bit, and 32bit versions. Most websites run just fine with the 64 bit version, but Adobe are slackers, XP64's been around for quite some time, and now Vista64, but they cant be bothered to recompile shockwave/flash players for 64bit.
So if you wanna to use shockwave/flash you need to run the IE7 32bit binary. Funcionality is identical anyway, and I've noticed no difference in performance.
