Vista 64!! Problem
1 Feb 2008
Hello,
When I am installing Vista 64...
"Where do you want to install Windows?" - Window heading
Both the HDDs come up on the screen and under 'name' heading its says....
"Disk 0 Unallocated Space"
and "Disk 1 Unallocated Space"
There is an option "format" but its greyed out
When I select either of the HDDs there is a warning message at bottom of screen saying:
"This computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu."
Then when I ignore this warning and click "next" it says...
"Windows is unable to find a system volume that meets its criteria for installation"
Neither of my HDDs will work?
Both brand new... there is something subtley wrong but I cant see it.
Please Help
Much appreciated
Thanks for reading :)
[Asus P5KC, 2 x 500GB Sata II HDDs]
Most Likely culprit =
The Disk O and Disk 1 are SATA
Your Motherboard's SATA controler, is simply unknown properly by Vista.
What you need is to get the SATA Drivers for the SATA Controler onto a Floppy disk so the install can use them.
Thanks for interest m8
I got a CD w/ mobo - asus p5kc
It says it has vista drivers inside
problem: the CD does not run automatically (even though it says it does) and comes up with some messages on screen including:
corrupt or unpartitioned drive 01
and it waiting for an input
Any ideas?
Ok i have had that problem only on one motherboard out of 4.
It turned out that it was the USB Stick that was plugged in when trying to install.
