Vista 64bit BSOD's
22 Oct 2005
Moving...
I've just installed vista 64bit but i'm getting a lot of BSOD's, however they occur less frequently when put my cpu and ram back to stock speeds. It's 12hours Orthos stable in XP so I dont know why its screwing up. Any ideas?
And anyone know of a list of overclocking apps and utilities that work under Vista X64?
Chars
How are you overclocking?
What are you overclocking to?
When everything is at stock does it still BSOD at all and if so how much less often?
What hardware are you running?
Why couldn't you be bothered to provide any of this information in the first place?
What is the meaning of life?
Just upping the FSB in BIOS
In sig
2 hours with no BSOD so far completely at stock, about once every half hour at max OC, bout once an hour on about 1/2 max OC
In sig
I pretty much did apart from specific failure rates...cos I dont know what they are yet :p
To live happily ever after..... :o
Apologies, my crappy work screen is so dark I couldn't see your signature.
Anyway I suggest wacking up your Vcore. My overclock BSOD'd on startup at 1.35V but at 1.375 it's rock solid.
lordedmond said:
have you put on the 4 gig patch from MS
You have a link for this please.....
By not having this patch,Could this be the cause of my random blue screens and lockups am getting in vista 64bit
Plus :shouldn't window update auto install this patch :confused:
IAmATeaf said:
Have you memtest'ed the RAM at the overclocked speed to see if it's stable?
Well its 12 hours stable on Orthos blend test which tests cpu and ram pretty hardcore so I would have thought its ok.
No worries! My Vcore is already at 1.45 so I dont really wanna push much further than that.
It's still running ok so I think I might just have to lower my overclock :(
There's also the reason that 32-bit stable doesn't mean 64-bit stable. Try running a 64-bit edition of prime95 perhaps...
