VISTA - 64Bit or 32Bit?
18 Oct 2002
Ok, I've got a retail copy of Vista ultimate. I have an AMD Athlon 64Bit 3200 CPU. Is it worth installing the 64bit OS or sticking with the 32 bit one? I've just installed the 32 bit one and its great. any ideas?
thanks
greg
i dont think your cpu is a AMD X2 ;)
if you had a duel core then yes, go for 64bit. i know i want too some point.
i probably wait for a month or two so drives and updates come out, then i will upgrade.
I don't see how the number of cores your CPU has should affect this decision.
64-bit is a longer term commitment. It could cause you some aggro for the first few months (due to drivers) but it will pay off by the summer.
32-bit will possibly give you a better out-of-the-box experience but you'll wish you hadn't chose it by Q3/Q4.
Is performance between 32 and 64 bit noticable then?
Also do you know what games currently run under 64? Thats the only thing stopping me from upgrading at the moment. Must be able to run CSS, BF2 etc. :p
The performance difference is quite substantial however it is barely visible at the moment with today's software.
It will certainly be interesting watching people's reactions here when they see a 32 vs 64-bit benchmark comparison with a game like, let's say, "Crysis" ;)
Ok chaps, I plan to do a format by the summer, so i'll stick with this 32bit version at the moment.
many thanks
Greg
Everything runs in it. Well that I've tried anyway. :) CSS and BF2 are fine.
Just built my new Pc this morning and stuck Vista 64 on it. All looks like it's running great, have tried BF2142, Oblivion and EVE so far.
I'm using Vista x64,driver support is good as 32 bit version,infact only driver I can't find is also not available in Vista x68 version(Leadtek usb dtv tuner),all my games run fine under X64,these include Steam games ie CS,TFC etc...Vanguard,UFO-Afterlight,Morrowind and all expansion packs to name but a few.
All my 32bit software works fine too, there's really no reason to go to 32 bit version unless you have a lot of bad driver support.
