Vista 64bit overclocking toolkit?
18 Oct 2002
Leicester
Hi,
What progams can I use to aid my overclocking?
CPUZ doesnt work for monitoring speeds. Nor Speedfan for temperatures. Not sure what I can use to put full load on the dual AMD cores?
Chees for any help!
Ant.
Ive been using prime orthos beta which seems to work fine. I cant get coretemp to work either which is the other temp program i use.
JaseUK said:
According to speedfan's website it should work ok with 64bit.
http://www.almico.com/speedfan.php
Speedfan needs signed drivers to work, that it hasn't got yet. I guess if I disable signed driver it would work... but you have to do it every time you boot up. I can't be arsed with that!
EDIT:
Attention Vista 64 clockers!
Everest 3.5 is the solution, the CPU ID and Temp monitoring works correctly with this program. :)
