You can move 64-bit numbers around? That's twice the width you usually have.BubbySoup said:As a gamer, can anyone tell me what advantages Vista64 will have over Vista32 in let's say, the next year or 2, because right now, all I am seeing is the ability to address more than 3Gb of RAM.
Everyone keeps saying go for 64, but really I do not see any point in the next few years unless you are going to hit this 3Gb limit a lot.
That's because they're run in 32-bit mode - the OS switches the processor back to 32-bit mode for the code that requires it.BubbySoup said:To what end? The 64bit version of Vista runs games at the same speed as the 32bit version, give or take the odd few frames here and there.
::: CooliceT :: said:im in the same situtation also.
but regarding the 64bit version. i have my two raptors running in RAID 0. and i have split them into 70gig partitions. one for windows xp pro. other for vista.
but the thing is. last time i tried to install windows xp pro 64bit. it was having problems finding the RAID 0 and the controllers when you install it, and boot the driver from the floppy... do you have to do this for windows vista 64 aswell?
has anyone got there's on a RAID 0???
also... if you purchase the 32bit version. can you order that dvd for the 64 bit aswell for £7?
im very tempted to upgrade to 64, but i may wait till crysis is out, then upgrade my graphics card to 8800, then purchase vista too.
Because:BubbySoup said:Yep, I see that which brings me back to my original statement that, in the next year or 2, what is the advantage of having Vista64 over Vista32 games wise?
littledave said:Vista will install to the raid partition no problems.
XP requires the Driver from the floppy
