It's time to give it another lash but hopefully this time it will stay on the main hard drive. My previous attempt was fruitful but the main source of frustration was the wireless connection. When playing BF2 it added an extra 30-40 ms when compared to the old xp installation. I'm having a hard time finding a suitable wireless usb solution that is supported up front.
My question is to all the 64bit vista users. What method do you use to connect to the internet? and if you do use a wireless usb can you state the model number. Thanks.
