Vista activation problem
Don
18 Oct 2002
Notts
I was given a new laptop from work a while ago but never got round to using it
I turned it on today and get the screen
If I try and activate I get a DNS error
Apparantly this is a known issue with the Enterprise volume licensing stuff
All fixes seem to refer to going into Control Panel and re entering your licence key
However I cannot getfully into windows just a restricted version which only allows web access
any ideas ?
I haven't but all the web pages say you cannot use telephone activation when using a volume licensing key
You can't use MS to activate AFAIK. If work gave you the lappy then they must have a KMS server at work. You lappy needs to talk to that server, if you get access to work from home via VPN then you may be stuffed so you'll need to take it into work.
thats what I was beginning to think
