Vista advice
27 Jan 2005
Letchworth Herts uk
Hi there just want a bit of advice ,if you bought the vista 32x OEM and installed it ,then desided to change to the 64x OEM would this be ok ? :confused:
dirtydog said:
How do you mean? You would need to buy the 64-bit OEM version separately if you wanted to do that.
yes that is what i meant,sorry ,if i bought both copies OEM ,then ran the 32 bit for a while ,then desided to go 64bit ,would that be ok ? :confused:
You'd be buying a whole new license so yes it would. (why wouldn't it be? ;)) You'd have to reinstall from scratch of course, rather than 'upgrade' from 32-bit to 64-bit.
yeah i know that ,but i am always backing up my system to cds ,i like to save everything i can on disc ,programs,pictures etc ,helps for a major update like this ,i just want to run Vista until its a lot more stable on x64 bit .. ;)
