Vista alternative to PeerGuardian?
26 Feb 2004
Hampshire, England.
As per the title: what are my options? Currently PG doesn't appear to have support for Vista…
Cheers,
SW.
if your using torrents. and want some more protection. most can use ip filters these days. making problems like errguardian not needed.
Well although i agree with Usenet, as its infinately better than torrents could ever be :)
uTorrent which you should (if not why not?) be using for your torrents can use ipfilters. Just place the the file "ipfilter.dat" in the %appdata%utorrent folder and make sure filtering is enabled in utorrent. Easy :) No extra useless programs taking up space/time, this is not opening the debate as to actually how usefull filters actually are though :p
