ok after a day of recovering my Vista Ultimate 64 install....
Have run into a problem with the 4 sticks of DDR2 geil memory.
If I take 2 out then everything seems fine. Pop the other 2 in and blue screen.... bad.
On the sticks it states settings of .... 4 4 4 12 Voltage 2.1 volts.
Then on the Geil website it states they can run upto 3 Volts so use 2.8!
My mobo - Intel Bad Axe 2 ... volts can be 2.12 or slightly less... so which is better...
just getting the MS update ... but its got to be BIOS settings problem.
Just not sure which to set now.
