- 18 Oct 2002
- London, UK
Hi,
I've got a problem with Vista's network connection on my wired LAN connection. My DHCP server gives out a gateway... as it should... fine... but I have specified a default gateway in the connection settings that is different. On XP this is fine... works with no issue... but on Vista... it always adds the route to the DHCP gateway above my specified gateway in the routing table... If I do an ipconfig then my specified gateway is above the DHCP supplied gateway... but I don't know why this is reversed in the routing table...
As both gateways are internet facing everything still works, but the DHCP supplied gateway is on a really slow connection to the t'internet... I have to manually delete the route everytime I connect to the network... It's driving me nuts as sometimes I forget... I don't really want to automate the deleting of the route as then I'd have to bypass UAC or click on the allow program prompt each time...
Any ideas on how to make Vista's routing table match the one generated in XP?
Changing the gateway on the DHCP server is not an option by the way as this is a business network.
Cheers,
Melon.
Cheers,
Melon.
