vista and issues
10 Sep 2003
(1) i have some HP inkjet printers for which no vista driver is available on the HP page. HP has said the only way to overcome this issue is to buy new models of HP printers.
is there any way of overcoming this problem?
(2) Is there any need of installing anti-virus software with Vista ultimate?
(3) I heard vista recognises the motherboard and will only ever work with that one motherboard in furure reinstalls of the OS. Is this true?
(4) My WD Raptor 74Gb which is 2 years old is becoming noisier and noisier. What can be done about this? Would WD accept this reason for an RMA under warranty? Can it mean a fresh install of windows is required?
with the hp printer you can try to install it as another model to get it to work.
Does it not tell you a alternative driver you can use on the HP site for instance my HP deskjet 6122 I have to install it as a 6500 series to get it to work
