Vista and Microphone Boosting
12 Feb 2007
South Shields
Any ides? Ive got a mic and there appears to be no option anywhere to boost the Mic. XP has it, Vista doesn't. Anyone got any ideas?
Using X-Fi Extreme Audio and a Medusa 5.1 Headset.
Control panel
sounds
click recording tab
select mike, click properties
select custom tab
tadaaaaaaaaaaaaa
how about taadaaah. not there ;) . Tried that already, the reason im asking is coz i cannot do it. The only thing that is there is Do Not Monitor . . . .
Ive just gotten an email from Creative . . .
Dear Phil, Thank you for reaching us at Creative Customer Support Services again; we appreciate the opportunity to assist you.
With regards to your reply, I understand that you are actually dual-booting on your computer. This, I believe, may be the problem here. I would not suggest that you uninstall either one of the OS on your computer but we actually do not recommend that you install your sound card and dual-boot on one computer.
If you might want to try, you may remove your sound card and install it on another computer running on the Vista x64.
Do you face the same problem? I certainly hope the above step(s)/information will resolve your query/problem completely and I look forward to your favourable reply soon. Do not hesitate to contact Creative Customer Support Services again should you have any clarifications in future.
So basically, if anyone out there has a Creative X-FI Xtreme Audio, could you please let me know if you have Vista 64-bit, and have the Microphone Boost option on your system.
