- 3 Oct 2006
how do i do it, before i try it and rooster it up, what do i need to download, what will i need?
2 SATA 160GB samsungs...
Craig321 said:Should just need a CD/floppy/some kind of drive with the RAID drivers on. When Vista is installing it'll ask if you have any additional drivers before it starts the setup.
bringerofdecay said:can you link me to the drivers, i had a quick look on microsofts sight, but gleaned nowt
Craig321 said:Put your motherboard model in to the manufacturers website and it should give you a list of latest drivers![]()
bringerofdecay said:ahhh, ok, thanks...can i use a DVD to install them? (dont have floppy drive, or spare CD)
Craig321 said:A bit of a waste putting ~1mb of files on a DVD, but yep you could probably use one![]()
bringerofdecay said:they're RW's![]()
bringerofdecay said:sheesh, asus homepage is slow....:/
Craig321 said:Ah, cool
Yup, it's sometimes super slow![]()
Craig321 said:Doesn't look like it's there
Are you sure your board supports RAID?
Craig321 said:That's strange, I can't see the RAID driver anywhere there
Saying that... it doesn't even list USB2 drivers![]()
Craig321 said:Check out the CD that came with the motherboard, it might have the drivers![]()
bringerofdecay said:so i just stick that in before i install vista? or does it prompt before install?
Craig321 said:IIRC it asks you during the Vista install if you have any extra drivers that need to be installed before Vista gets installed, at that point put the CD in... but make sure the RAID drivers are actually on there before you start![]()
bringerofdecay said:ok, the disk comes with the jmicron raid thingy, so i'm assuming thats it, i don't mind installing it not in raid, but raid would be nice, thanks for your help
Craig321 said:Ohhh, that's why it wasn't listed with your motherboard... it's a separate RAID card, right?
In that case stick the jmicron CD in when Vista asks you for additional drivers and you should be good to go![]()
hope it works ffs
