Vista autoplay issues!
24 Apr 2008
Essex
Got some serious issues with vista and the autoplay feature. :(
For some reason it displays briefly when a dvd is put in the drive but disappears after about 1 second!! So before I can choose anything it has gone and after that even right clicking on the dvd drive does not display an option for autoplay.
If I then take the dvd out and put it back in it will do the same thing 90% of the time- the odd 10% it actually works as should do!
What can I do?! I've never had this problem before - the ony thing that springs to mind is that I am using vista x64 now rather than x86 :confused:
Goto control panel/autoplay and set all you want ??
You not tried that ?
Using vista ultimate x64 and no issues, When OS gets redone i setup autoplay for all options and job's a good'un
