Vista AVI Problem
5 Mar 2006
Scotland
Just installed Vista...and for some reason it wont play AVI files/divx.
I have installed the Vista Codec pack (latest)...then tried with also AC3 filter, Divx codec and XVid codec ...still doesnt work!
Any ideas???
I could...but with the right codecs and WMP the you should have any problems. I used the same combination with XP but its not happening with Vista. Id prefer to get it working with WMP
ffdshow will work with WMP.
Install FFDshow and have it decode xvid/divx etc codecs.
Thanks...but for some strange reason its workin today....all files in WMP????? I installed a few extra updates...that must have helped.
Cheers
