vista avi question
Man of Honour
11 Mar 2004
is there anyway to get vista to display preview icons for avi, it does it for mpg files?
Where it uses the first frame as the icon.
If you have the correct codecs for the avi, it will do a preview. otherwise it will just show the icon.
saying that, i had great problems trying to get thumbnails for x64. I bet your using that?
I am using version 4.5.0 plus the x64 tools. All of my AVIs give previews. x64 tools is only to get it to play in Media Centre of Media player x64 (located in program files and not used as default).
Yay !!!
Sorted :)
Just so I know, whenever people mention x64 they just mean 64bit Vista right ?
Its not some fancy way of using 64bit vista ?
Hmmm..... I did wonder why in My Computer I have Program Files and Program Filesx86 !!
Guess it doesn't really matter when you install the stuff though, be it 32 or 64 bit !! :)
