Vista + Belkin wireless card
11 Mar 2006
Hi,
I've just installed windows vista on my computer, and when i go to install my belkin pre-n wireless card, the drivers install correctly but the wireless wont work and when i go to device manager it says that the device does not have enough recourse (code 12) and to disable some others. But no matter how many other devices i disable, the same message displays.
I have had this belkin card running on windows vista on my laptop fine, but im getting this problem when trying to use it on my computer.
Can anyone help?
Cheers
AMD
Hey mate, this might not apply to you as it's a different Belkin card, however mine simply refused to work using Vista, I've now had to go wired. Sorry, hope it works out for you
I had this problem with the wireless G+ MIMO usb adapter, had to go to a different website and download the drivers, around 32mb, now runs as sweet as a nut
I doubt they're gonna bring out any new drivers any time soon haha.
I think it may be because i'm using a pci-pcmcia adapter, so it thinks there are 2 devices in the one PCi slot :S.
Any ideas of how to solve this?
Can i tell it which resources to give to the seperate devices?
