I have a MX 5000 and vista x64 running with no problems
U will not be able to use your Bluetooth in vista unless u have installed the Bluetooth software from Logitech’s site if u have not done so link is here: http://www.logitech.com/index.cfm/433/3024&cl=gb,en
Then once installed you will see the Bluetooth stack in control panel of vista.
I was under the impression that the Bluetooth dongle with the the DiNovo Edge was only designed to function with the keyboard itself and not as a possible point for other BT devices ?
Yep your right, it seems logitech in their wisdom, have decided that the dongle that comes with the edge will only connect to the edge.
I have sorted it by using an old dongle that came with a dinovo laser.
