Vista Boot auto disable driver signing problem
3 Dec 2007
Essex
Hi All,
Some time ago, i disabled the Vista Driver signing option on Boot.
I cannot remember for the life of me, how i managed to auto select this option every time I boot up.
Basically every time I boot some form of script runs which automatically selects F8 and then selects disable driver enforcement.
I want to upgrade to Windows 7, however i cant seem to boot from CD, even though i changed the BIOS settings to boot from CD.
I get the prompt which says boot from cd, press any key, however upon pressing any key nothing happens and it goes straight into the F8 screen whereby it automatically selects disable driver enforcement.
I can use the keyboard in the BIOS screen. I have two CD drives so i dont believe its the CD drive as it reads that there is a disk in there. I'm not sure whether the problem is to do with the script which auto takes me to the f8 screen....
How do I disable this script??? lol. I havent used the PC for a years and half and cannot remember how I did it or remove it.
Any clues? or other thoughts on how to get it to boot from CD?
Thanks
