Vista boot issue.
26 Feb 2004
Hampshire, England.
Guys,
I’ve introduced my old XP backup drive to my Vista build and I’m now confronted with a dual-boot screen at start up? All the drive has on it is data, it has never had an os installed?
My options are:
An earlier version of Windows or
Windows Vista
If I switch on and walk away, the first option is selected and the machine goes round in circles, unable to boot any os…
In Windows I wanted to change the drive letter (its oddly set to F:) but it won’t let me – it says its not possible :(
What can I do to be able to lose the boot screen and be able to change the drive letter – its really starting to frustrate me :)
Cheers,
SW.
Cheers mate - any idea why it is happening though?
And will I then be able to change my drive letter :(
SW.
EDIT: Isn't easybcd pretty good too - i think I've used that in the past?
Changing the system drive letter is not a recommended procedure, but it can be done:
You need to change the registry entry "\DosDevices\X:" (where X: is the current letter of your system partition), to be "\DosDevices\C:" ,in:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices\
And reboot.
Just make sure that "\DosDevices\C:" isn't already taken up by another drive. If it is, rename that to something unused first.
