I Thought I'd give vista another go since creative released some vista drives for the Audigy2 that I've had since 2003. It's served me well under XP.
Anyway, installed vista ultimate, then the drivers... rebooted hooray!
No, not hooray, it got as far as loading windows up until the little bar animation under windows logo (Vista loading screen, I suppose, is what I'm trying to describe) then fell over. Rebooted itself... and kept doing this.
Tried booting it into safe mode - no joy, same thing. Got so far then fell over.
Went back to XP - installed the drivers from the Audigy2 CD that came with the card... fine. Windows update decided it had some newer drivers, so I thought I'd try to install them. Rebooted, windows loading screen.... bonk. Dead. Looked like a quick flash of a BSOD then rebooted... meh!
But I managed to get into XP in safe mode, uninstalled the drivers via control panel, rebooted and reinstalled the originals - it's fine.
I don't want to use the onboard sound on my motherboard because, quite frankly, it's ****. I will go out and buy a new soundcard, but first I would like to know if anyone has any idea why anything other than ancient drivers on XP kills my PC.
Anyone got an old Audigy2 running under vista with no issues? Which drivers are you using?
