I have a hard drive which i had dual booted between Windows XP and Mandriva Linux using the LILO boot loader. After recieving Vista i went into the Vista installer, removed the partitions containing vista then created a new partition for vista with this spare space.
The installation went through fine and Vista booted up with no problems. After installing a few drivers i removed the Vista DVD then rebooted the machine. When booting up instead of getting the dual boot screen i get "L 99 99 99 99" with the 99's repeating about 70 times.
If i put the Vista DVD in the machine it will boot up into XP or Vista fine.
I remember this L 99 99 99 99 problem when i mucked up LILO in Mandriva previously so i'm pretty sure it's to do with this, however now that ive removed the Mandriva partitions i can't get back into it to check LILO.
Any ideas?
P.S - I wasn't sure whether this thread should be made here or in the Linux forums so feel free to move it if necessary mods.
EDIT: I forgot to mention, i've gone into the Vista recovery section, checked for boot problems and it didn't fine any, and also tried repairing the MBR by going into a command prompt with the recovery console and typing BootRec.exe /fixmbr
Any ideas?
