On Vista write caching on SATA hard drives (dont know if this applies to all hard drives) is disabled by default..
You can enable it but there is a very clear warning that by doing "a power outage or equipment failure might result in data loss or corruption". There is another check box below it which allows you to further enhance the performance, at the cost of an even higher risk of data loss on "equipment failure".
Now, I am assuming that this "equipment failure" essentially means BSODs, lockups, etc - since this is ostensibly the same as if the power died anyway. My PC is on a UPS but I'm always on the bleeding edge of performance, and overclock most of my system. Right now I'm torn between thinking what kind of performance improvement this could give, and worrying about "what if the next time I get a BSOD I can't boot Vista?"
Have any of you enabled this? Any feedback you can give?
