Vista Experience Index
8 Jun 2007
Hi
My exprience comes out at 5.1 - everything is 5.9 except my ram.
Ram is Corsair 2GB (2x1GB) DDR2 Dominator PC2-8500 Dual Channel Kit (yep it set correctly in the bios 5-5-5 etc)
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
Is there any obvious reason it is lagging behind ??
Would appreciate any feedback
My ram, 2GB Corsair XMS TwinX Platinum DDR400 CAS3 in Dual channel gets a 5.0 so Vista index isn't really everything :p
i think thats about right for 2gb ddr400 cas3...
i am sure it goes by the bandwidth and/or the read&write speed of the memory
Screen res your running at the time can effect your ram score.
Try running at the lowest res you can & re-run the test.
snazzy_dazzy said:
I get a vista score of 5.9 for my ram.
its my ****ing hdd that drags my score down to 5.5 :mad:
5.5 isnt that bad, if you had two computers running side by side, on one machine you had a Index score of 5.5 for your HDD and on the other a score of 5.9, but you wouldn't notice the difference.
Anyway 5.9 here for me. :D
