Vista hd question.
11 Jul 2003
Telford//west mids
Installed vista and cant play my game`s without crashing every 5 mins or so,question i need to ask is if i buy another hd and install xp on it and when vista works better can i just put the hd in with vista and will it work ok,just save`s me going through microsoft to activate it again.
In a nutshell yes. As long as you have the same mob etc. There should be no problems. Buy another HD, Take out the one with Vista on it And replace it with the one you wish to install XP On. But, Store your Vista Hd carefully, don't forget that is the piece of hardware it was registered with.
Yeh will be keeping the same hardware,pity about vista but i`ll put it back on when it`s more stable.
Thank`s :)
