Vista Help
9 Jul 2005
High Wycombe
just trying to install home premium 64bit vista and keep getting
"windows in unable to find a system volume that meets its criteria for installation"
Am trying to install on a raid 0, managed to do it before but needed to swap out my hdd and put in smaller ones - cant remember how I did it!!
Any help appreciated
Ive tried 2 40gb drives, now its working fine with my 2 500gb drives with vista, but keeps coming up with unable to find system volume with both my 40gb and 2 160gb disks. Mobo settings must be ok as the 500s work, just cant get it to install on any others.
Its a pain as I need the 500s for another build!
Have tried a number of different RAID drivers and then it doesnt even see them! I'm stumped!
Been at it most of the night and still have the same problem! Anyone got a step by step guide for a DFI ultra-d Lanparty? How do I set up either the mobo or hdds to give windows vista a system volume in raid 0 that meets the criteria (whatever that is!!)
Cheers
Now I am trying to install windows XP X64 first (as that might be how I did it before) but it keeps resetting!!!!!!!
Cant seem to get any operating system on there!
i had this but when trying to install onto a 2nd harddrive (which was using a differnt controller) how i fixed it is in the bios setting the that harddrive/controller has the primary boot , then i was able to install vista , afterwards swiched it back (i have xp on a 500gb seagate and vista on a 200gb maxtor) and i just press F8 in the boot up and select the hard drive i want to boot from (nice handy option my motherboard)
Thanks for the info. Have installed on a single drive no problems, just cant get it to work in RAID 0 - seems a shame not to use that extra speed as I have 2 drives the same.
Given up - cant be bothered with raid anymore.
But now have sound driver issues with vista 32 - anyone know how I can get the sound to work on an old advent T9102 - think its a realtek onboard soundcard but the download ends up giving high definition device driver problem - not the normal soundcard stuff I'm used too.
Tech specs say its a Realtek High Definition Audio (Azalia)
Just for anyone who might want to know - I used the xp drivers off the MS 7046 mobo, this meant I had to do a system restore to a seperate Hdd off the cd that came with the machine to get them, then used the C-Media 5.12.01.0008_AZA sound driver IN xp compatability mode.
This has worked, although I'm not sure how!
Hope that helps someone else and saves them 14 hours of frustration
