- 17 Dec 2004
- Newport
Hi All
Hope someone can help I've spent about 5 hours on this so far and its doing me in
I have Vista Ultimate, and I have Sun Java installed, when I try to go to a Java Enabled site nothing happens, I have uninstalled, and reinstalled from the Sun site more times that I care to remember, by various methods, (online offline install etc)
The Java icon doesn't appear in the system tray or anything.
If I try to open the Sun Java Console nothing happens.
If I run IE as an administrator (right click icon and "Run as administrator") it works, If I don’t use UAC it works.
If I create a new account from scratch - it works
If I use Firefox it works.
But it doesn’t in my user account.
I want UAC ON. So the solution is not “switch it off!”
I use IE mainly so I don’t want to fully switch to Firefox.
Any ideas how to get it working again? It used to be fine and worked ok. Last time it happened I ended up formatting and starting again, which I might do because I think I'll get a Velociraptor.
Anyway - any ideas to get it to work without having elevate privileges.
Appreciate any help
Cheers
Shunts...
Appreciate any help
Cheers
Shunts...
