Vista installation error
27 Apr 2007
Got another Maxtor 500G SATA HD today , Decided Upgrade my XP to Vista64 (HTPC) but when installing keep getting the following error
any ideas how to fix ?
Has me stumped
Solved by removing the HD and Formatted using Paragon Partition Manager 9.0 Professional Vista Compatible, on other pc.
Format and use the " install new OS option to create the correct mbr "
