In January I purchased Vista Ultimate x86 and installed it on a partition so I could dual boot between it and XP Pro. All went ok and for the last few months I've been using Vista without any problems only going back into XP for BF2142 and Trackmania.
This morning my new setup arrived (Gigabyte DS3, Intel E2160, OCZ ram) and I set about fitting the new components. Rather than go down the dual boot route again I decided to stick with Vista alone.
I booted from the DVD, waited patiently, chose my location, language and keyboard setting before it got to the Repair or Install screen. I chose install but a few seconds later a box appeared saying there was a missing CD/DVD device driver and asked me to insert the appropraite cd, floppy disc or removale device. The only options available to me were "Browse", "Rescan" or quit installation. The "next" button was greyed out.
Obviously the DVD drive is working perfectly so why does it get to the same point every time and say there's a device driver missing for the optical drive??
Anyone else had this problem?
