I have Vista home premium installed on my new machine, and since getting it up and running I have had endless amounts of problems with it.
So far, it wont take my broadband installation disc, so cannot install broadband on it, its not even recognising it when I download the drivers from my old machine, and copy them across on a CD.
I cannot install the drivers for the mobo (however, resolved this now) or the graphics card (downloaded the latest patch, and copied across, and it now recognises the graphics card). However, it still doesnt recognise the card when I put the disc in.
Question is. If I uninstall Vista, and then install windows XP, then add all the sortware needed from the broadband setup disc, and mobo/graphics card disc, can I then upgrade to Vista without losing all the drivers etc...
Also, whats the easiest way to uninstall and install XP? Im not good with all this technical stuff so want it as simple as possible if you will.
Can I just enter the BIOS, and change the boot options and put the CD drive before the HDD, so that when I switch the machine on it will boot from the XP boot disc rather than straight into Vista?
Once in, can I then just install XP? Or do I need to reformat my HDD before exiting the BIOS?
