Hi guys!
I seem to have a problem with my main pc
i do a fresh install run the auto updates, its fine for a while 2/3 days. Then it will download Vista SP1 and will reboot and run chkdsk (its done this 6 times in a row now) chkdsk finishes with no errors i think and windows will no longer boot at all safe mode / recovery anything.
Its a legal copy of vista, i can boot from linux and get the bootex.log
Any ideas ?
i do a fresh install run the auto updates, its fine for a while 2/3 days. Then it will download Vista SP1 and will reboot and run chkdsk (its done this 6 times in a row now) chkdsk finishes with no errors i think and windows will no longer boot at all safe mode / recovery anything.Its a legal copy of vista, i can boot from linux and get the bootex.log
Code:
*********Log file*************
Checking file system on C:
The type of the file system is NTFS.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Attribute record of type 0x80 and instance tag 0x4 is cross linked
starting at 0xa6cb4 for possibly 0x5 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x4
in file 0x9126 is already in use.
Deleting corrupt attribute record (128, "")
from file record segment 37158.
starting at 0x1555 for possibly 0x58 clusters.
in file 0xba75 is already in use.
from file record segment 47733.
144512 file records processed.
131 large file records processed.
0 bad file records processed.
0 EA records processed.
44 reparse records processed.
Repairing Usn Journal file record segment.
34074056 USN bytes processed.
Usn Journal verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
244195327 KB total disk space.
41884592 KB in 117735 files.
70432 KB in 22444 indexes.
0 KB in bad sectors.
254459 KB in use by the system.
65536 KB occupied by the log file.
201985844 KB available on disk.
4096 bytes in each allocation unit.
61048831 total allocation units on disk.
50496461 allocation units available on disk.
Internal Info:
80 34 02 00 a1 23 02 00 2d ca 03 00 00 00 00 00 .4...#..-.......
43 00 00 00 2c 00 00 00 00 00 00 00 00 00 00 00 C...,...........
e0 64 53 77 00 00 00 00 50 23 14 ff 00 00 00 00 .dSw....P#......
Windows has finished checking your disk.
Please wait while your computer restarts.
Any ideas ?
