i am running vista32 and pretty much got settled with it now, but i have had to start using a wifi connection now and i am getting lag spikes every 60 seconds or so now. I am on my 2nd wifi adapter now and the problem is the same. its wrecking my gamming enjoyment to be honest.
Is there a cure?
I have tried the antilag program- didn't work
I have tried to disable the wlan autoconfig in services and use the adpater software, but disbaling that stops all networks.
I am at my wits end.. Have I really got to install XP again??????
Please help network Gurus
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\jamie>ping 10.0.0.2 /t
Pinging 10.0.0.2 with 32 bytes of data:
Reply from 10.0.0.2: bytes=32 time=1ms TTL=64
Reply from 10.0.0.2: bytes=32 time=2ms TTL=64
Reply from 10.0.0.2: bytes=32 time=783ms TTL=64
Reply from 10.0.0.2: bytes=32 time=726ms TTL=64
Is there a cure?
