vista not auto detecting devices
21 Jul 2005
not sure what i've done to it, but when i put in say a usb key, normally it would automatically find the drivers, but now i have to manually point it to c:\windows\system32 the first time a new device is installed.
what do i need doing to fix that?
I know how annoying that is. Every time i had to do it again if I unplugged the usb key and put it back in later.
I couldnt find a fix, I had to reinstall. Its a definite issue.
oh fs!
reinstalled, did all the update/installed my software and its come back again! :( a weird side effect is that normally if i winkey+pause, the device manager shortcut on the left side pane, doesnt open device manager but if i go into advanced settings, hardware, device manager, it works fine.
its not a big deal but the prompting for drivers thing is not acceptable.
i dont know if its something on windows update screwing me or something else. with hindsight, i probably should've reboot after each program install to see what was causing it but didnt think software was the problem.
I have the notion that this is a bug in Vista. Like you it happens to me sometimes but not others. it happens with different USB pens and external HDD's and the next time I plug them in they work fine. Its annoying though I don't know of a fix.
well i'm going through yet another reinstall but doing things bit by bit this time (install few apps, reboot, test) and then making a ghost image of it so i can fall back on a backup.
i wanna find out why this i, because if breaks the device manager link the system properties, then who knows what else it has broken that i cant see but might be vital.
i think whatever it is that is breaking the dev manager link is also breaking the auto driver install.
i also notice that hibernate goes missing in the shutdown menu but on a fresh install, its there but if i set the shutdown button to hibernate, it still "works" --i assume it works, i dont get any sort of hibernate screen just a black screen instead..
found the cause of the device manager thing breaking, its a imageshack quickloader of all things breaking it!
the usb problem slipped by me again, cant be bothered with that anymore and i hope ms fix that with sp1, as its annoying having to manually point to \windows\system32 three times to detect a new hdd!
