Vista not reading DVDs
Man of Honour
17 Nov 2003
Southampton, UK
My housemate recently ran Ccleaner on his Vista machine. Since he did this, he can only read CDs and not DVDs. It just says that there is no disc in the drive.
I've done a google and saw something on removing registry keys for the upper and lower filters, but it hasn't helped.
Any ideas?
Burnsy
No, but we have unistalled the device and reinstalled it to no avail.
I don't think it's a hardware issue from what I can tell.
Burnsy
Hey Burnsy2023, to check if it isnt the actual DVD Drive itself (Highly unlikely), try booting of the Vista DVD. If it does this will eliminate the Drive itself.
The only thing i can currently think of is Ccleaner changed the region settings for some strange reason and this would prevent DVDs from being read.
Once he is logged into Vista go to My computer and then right click on the D Drive and then go to properties. Then go to the Hardware tab and click the correct DVD Drive under, All Disk Drives: This should bring up the properties of the DVD Drive itself. Select the DVD Region tab and then make sure it is set to the correct region. United Kingdon which is Region 2. :)
It won't read data DVDs either.
I see, sorry. :o
Edit: I was looking through the device manage and found that the drive was lited as a CDROM drive rather then DVD. My initial thought was that this was just usuing generic drivers and wasn't an issue, but I'm running out of ideas:
Screenshot : http://img488.imageshack.us/img488/3006/errorjp4.jpg
Thats fine, exactly the same on my system.
Have you tried unistalling the device and then restart the system, Vista should normally pick it straight back up and install the necessary drivers. :)
Have you tried uninstalling the IDE channels rather than the device and letting windows reinstall on boot as this has sometimes fixed CD/DVD issues for me in the past.
