I was looking on the web for a fix for the folder views in Vista not being saved and found this fix, this fix will also reset ALL folder views to the default settings and will also turn off auto template discovery, if you want Vista to auto determine the template for folders then remove that entry from the registry file.
Copy and paste the below into a text file and save it as "folderfix.reg", once you have created the .reg file just double click it to apply the fix, if the "Tools" tab in step one isn't available press F10.
Hope this helps!
Code:
Windows Registry Editor Version 5.00
; This is a Vista ONLY Folder Repair tool, This tool will force Vista to remember your folder settings by
; Modifying registry entries. Descriptions below explain what each step is doing.
; Steps:
; 1. Open up explorer and go to Tools->Folder Options->View and uncheck Remember each folder's View settings
; 2. Double Click this registry File
; 3. Restart Computer before doing anything else
; 4. Once restarted, bring up explorer again and put the Check back that was removed in step 1.
; 5. All folders on the computer should now be in the "All Items" format. Since Auto Discovery is now off
; you will need to go to your shell folders (Pictures, Videos, Contacts, Music, etc.) and set them to the
; template you want, apply to subfolders, etc.
; Clear out Folder Settings left over from XP:
[-HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\BagMRU]
[-HKEY_CURRENT_USER\Software\Microsoft\Windows\ShellNoRoam\Bags]
[-HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\BagMRU]
[-HKEY_CURRENT_USER\Software\Microsoft\Windows\Shell\Bags]
; Clear out Folder Settings for Vista
[-HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU]
[-HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags]
; Modify the Folder Storage space to 20000, this will allow the saving of settings for up to 20000 different folders.
[HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell]
"BagMRU Size"=dword:00004e20
; Turn off Vista's Auto Template Discovery. This keeps vista from deciding on it's own what type
; of Folder you have (ie, picture, videos, docs, etc) This will keep vista from changing what you
; have already set for a folder as well. Notice this value is in the Bags Key that was deleted
; in the settings above. Remember this is there because if you decide to manually go delete
; your Bags Key, you will lose this value and auto-discovery will turn back on again.
[HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell]
"FolderType"="NotSpecified"
Hope this helps!
