Vista Not Showing Correct CPU Speed
29 Sep 2008
Can anyone tell me if its possible to get vista to report the correct CPU speed plz.
Have a Q6000 at 3.4ghz (400 x 8) using vista ultimate 64bit, yet it's showing at 3.6ghz within windows (showing correct speed in everest, cpu-z etc). I have also tried to overclock my sisters E6600 in Vista Ultmate32 and that is showing the overclock in CPU-Z etc and in bios/boot up yet showing the standard speed in Vista. (cpu is not throttling back either)
Any help will be apreciated greatly as it's sending my OCD crazy:)
Hi and welcome :)
You can't get Vista to show the correct speed if you change the default CPU multiplier.
Not sure about your sisters problem. But always go by what CPU-Z says.
Thx for the fast reply Cob.
Damn vista it is sending my OCD into overdrive lol, i will just have to get 400 x 9 then :).
Had no idea either with my sisters as kept the multipler the same yet shows no diffrence in vista when i increase the FSB.
@Moomoo I wish Vista Could use my math level, i would have a wonderfull quad at 9Ghz :)
