Vista OEM..How many times can it be installed?
1 Dec 2004
S.Wales
If i were to purchase Vista OEM, How many times could i install it on the same machine?
i.e. if i were to install it, then 6 months i wanted to do a complete wipe and re-install, would it work?
What if i decided to change a piece of hardware..like the motherboard..and do a clean wipe, could i re-install it?
You can install it as many times as you want. You can't change the motherboard though, unless it breaks under warranty and is replaced by the supplier/manufacturer.
Im guessing this is the same for the processor too?
The GFX, HDD, RAM etc etc will count as an upgrade, and not a new system
You can change anything else as many times as you like just not the motherboard.
Surely people could say there board borked and then get a different board stating that it was replaced from the supplier/manufacturer.
When in reality all they had done is bought a new mobo?
The question is, how would they actually be able to know you got a replacement or just bought a new board.
Realistically, they can't.
Burnsy
