Vista problems...
  • Thread starter Thread starter Guest
  • Start date Start date
I installed the trial of alcohol 120% from their website yesterday on Vista Ultimate with no problems what so ever so it might be the version you're using?
really? why did they put a blue stripe round the edge of every window? thats a bit silly :eek:
change the windows theme to classic if you dont like it.
if your using Vista X64
no
its one of the security features built in. X64 also wont run any 16 bit code either.
so its not backwards compatibile with some really old stuff that may be kicking round on your HD.
and for what its worth, i get the same lines on my system, with ATI drivers
maybe if its not to your liking, try upping the colour intensity in windows colours and appearance. It makes the gradient between blue and transparent less obvious :)
