The only slight performance increase you would have is if you either had a partition on the same HDD or a seperate HDD and set the pagefile to take it from there.
Thx for reply guys. I have my pagefile set to a seperate HDD already. What size do you guys recommend with say 2Gb of Ram I currenly have set at 200mb.
