Bought an Advent Laptop for my daughter for xmas. It comes as;
1.4GhZ intel something or other
2Gig memory
Vista Home Premium
Ralink Wifi card
Wifi connects ok when I use Func + F10 (wifi enable) but even though I've got the connection set as "always connect to this network when available" (which is on all the time) I have to force it to connect each time with Func + F10. For some reason it's not connecting at start-up, even though its listed in the startup folder.
There IS a comment next to each of the entries in start-up folder, to the effect of approved or waiting approval etc for each of the different start-up programs/functions, however the Ralink/wifi part appears to be "not yet certified" or something similar (the laptop's stashed away at the moment), and does not appear to have the same approved status as a start-up function.
I've updated the wifi driver, but that appears to make no difference; it still forgets/wont connect automatically at power-up.
ANY IDEAS!!!!!? I don't know vista, and can't see what might improve this...!
Thanks as always...
2Gig memory
Vista Home Premium
Ralink Wifi card
Thanks as always...
