21 May 2007 at 17:35 #1 jamjar jamjar Soldato Joined 27 Jan 2005 Posts 2,702 Location Letchworth Herts uk Hi All Can anyone recommend a good reg cleaner that will work with Vista 32bit ? does Regseeker work ok ? thanks
21 May 2007 at 17:43 #2 sunderland sunderland Associate Joined 6 Jul 2006 Posts 1,507 Location co durham i use jv16 and it works ok,p.s it is only a trial for 30 days but you can always give it a try http://www.macecraft.com/downloads/
21 May 2007 at 17:55 #3 Duke Duke Man of Honour Joined 29 Jun 2003 Posts 34,673 Location Wiltshire CrapCleaner http://www.ccleaner.com/
21 May 2007 at 19:10 #4 iMacMart iMacMart Soldato Joined 8 Jun 2006 Posts 13,134 Location Hertfordshire CCleaner has done well for me in the past
21 May 2007 at 21:59 #5 jbloggs jbloggs Soldato Joined 4 Sep 2005 Posts 6,801 Location UK CCleaner also works on my Vista 64bit install without any problems.
