Hi,
Windows isn't booting at all (Vista 32) and following research, it was suggested I enter the advanced boot menu and select the repair tool.
On entering this, there isn't a repair too available!, the options are:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable Low Res Video
Last Known Good Configuration (advanced)
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable driver signature enforcement
Start windows normally.
Would you recommend I get the recovery disc from Toshiba? (it's a U400-124 notebook).
Thanks.
Safe Mode
Enable Boot Logging
Debugging Mode
Thanks.
