Vista restore / maximise animations
11 Sep 2005
Southport
Are there supposed to be any animations for maximise and restore in Vista? If I maximise a window it just 'happens', without any posh animation. This the same as on all installs? Just curious :)
PS I don't mean maximise from the task bar, I mean from when a window is already open...
AFAIK the only effect you're supposed to see is the window "popping" up; starting a little smaller than it should be and rapidly expanding to the correct size.
If I minimise the window falls back at an angle as it fades out (this takes perhpas a second or less), if I maximise from a minimised window, the same happens. The only time it doesnt happen is when there is a window maximised behind the window I maximise/minimise.
Edit: Ultimate x64 edition.
Edit: Ah, if a window is open and I maximise it, it just appears maximised. No animation.
