Vista running slow
11 Jul 2007
Newcastle Upon Tyne
Just did a fresh install of Vista ultimate on my old rig and it all appeared to be fine except that accessing things like control panel or installing windows updates or other applications seems to be taking far too long, it took the best part of 30 minutes just to install the intel chipset drivers and another 25 or so for the nvidia drivers.
Anyone come across this before or should i just reinstall vista again?
Nothing much has changed other than im using a new HD and ive enabled the jmicron controller so i can use an IDE dvd drive.
Tested with the controller disabled aswell once vista was on incase it was something to do with that but no change.
E8400
Asus Maximus Formula
8800 GTS
4GB RAM
