Vista shortcut keys?
24 Jun 2005
Sussex, UK
Just installed Vista, just wondering is there a keyboard shortcut for the "switch between windows" function, rather than clicking it in the quick launch bar...
Is there any major risks or vulnerabilities with disabling the UAC in Vista? just that with every file i download or certain applications i want to run, it keeps giving me a warning first, just makes the simplest of things slower.... is it fine to disable it?
UAC is the most annoying piece of poo ever. If i didnt want to open that program then i wouldnt of clocked on it, DUH!!!!
Moredhel said:
If you mean flip3d then the shortcut is win + tab.
I've turned off UAC personally.
cheers, that's exactly what i meant... i've also turned off UAC, no more warning messages at least... :)
It is more for when software gets installed without you knowing!
And in work, for not letting people install stuff they shouldn't
Quite handy TBH! :D
