Vista shutdown drop down options - can you re-order them?
20 Mar 2007
Sleep is the first option in the shut down list with Vista Home Premium on my Desktop. However, given the problems I have experienced trying to get the PC to successfully wake up again when using sleep option I have had to use the Hibernate feature instead (almost as quick at booting as sleep). Given this situation is there a way of making Hibernate the first option in the shutdown list in place of Sleep?
You can change the default action of the sleep/hibernate/shutdown button left of the padlock icon on the menu.
WotDa said:
Like this?
But with Hibernate instead?
Thanks for the response, however, my peepers aren't quite good enough to see what is going on on the second screen plus I use Windows Classic menus - haven't moved on since Windows 95 and although I've tried the new interface I really really really don't like it and don't find it very user friendly at all. Can this exercise be done for Classic?
Control panel > Power options > Change plan settings (Your current plan) > Change advanced > Power buttons and lid.
Ah! many thanks, a pictures worth a thousand words or so the saying goes. I was changing the power button action option to Hibernate and not the start menu power button option :eek: That has definitely cured it.
